nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Thu Aug 09, 2012 9:14 am
Don't forget to check the fan clutch, if it doesn't engage, it will not pull enough air through the radiator when speed are lower than 35-40.
Easy to check, with the engine off, if it spin freely without resistance, its bad. If you spin it and doesn't make a full revolution, its ok.
Also, when does it show heating up city or highway driving? If city, more than likely the fan clutch. If highway, look more toward the radiator.
The Jiggle valve should be at the 12 o'clock position, if you have it at any other position it just makes it harder to bleed the system, shouldn't cause it to overheat. Most vehicles came without a jiggle valve and have zero issues for the most part.
Have you flushed the radiator? How old is it? How is the radiator cap?<another thing to check
