help on my s14 sr20det into my s14. the speed governer problem.
tr0n9h
i am having problem with the mph. the needle would go all the way to the end real quick then once it hit 120 the car would bog and slow down. i know i am not going 120 for sure because it no car travel to 120 in 7 second. im pretty sure it the speed governer problem.
so then i cut 1 wire on the speed sensor and now it dosent have the problem but my gauge dosent work anymore.
i was wondering what speed sensor would i use to get the mph to be accurate and what can i do to remove the speed governer?
Modified by tr0n9h at 12:22 PM 7/30/2007
Hijacker
Car: '92 240sx Convertible
'94 F-150
Double check to make sure you have the proper speed sensor first. It sounds to me that it's either busted or the wrong one and sending info back to the ECU saying that you're accelerating faster than you should be.
tr0n9h
do i use the ka speed sensor from the s14? right now i am currently using the sr20 s14 speed sensor
CoupedUp
Car: 1993 Coupe
Yes sir, make sure youre using the KA speed sensor.
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
tr0n9h wrote:do i use the ka speed sensor from the s14? right now i am currently using the sr20 s14 speed sensor
You can use the SR S14 sensor but then you would need the JDM cluster, if you plan on using the stock 240 cluster then use the KA sensor.
