help on my 240
xplicit240
Car: 89 nissan 240sx
i just bought a 89 240 ... it came with alot of goodies.. but it only has a ka24e .. i wanted to buy a sr20 but now im just thinking i should just buy a de and turbo it .. any suggestions? in the end which will be better for me as the cost of money is concerned .. i dont want taht much hp anyways maybe 200 to 300 is sufficient . you can message me on aim if im on .. i need some help fixing this car i dont know where to start
Import_Ant
why dont you turbo the SOHC motor... if you're concerned w/ budget why spend the money swapping in a DOHC motor? the SOHC is perfectly capable of handling your power goals with ease. plus the injectors are top feed so you can cut cost further by using DSM 450cc injectors and a resistor box from a junked turbo DSM.
I'm just curious why everyone automatically assumes that more cams = more power?
the DOHC ka's had more power out of the box due to their higher compression ratio (89's were at 9.1:1 initially then went down to 8.6:1, DOHC KA's are set to 9.5 or 9.6:1 I believe in all years but even at that they're only rated at about 10 hp more from the factory)
Mustangs_Suck
meh...SOHC's are usually REALLY tired and wornout, and from what I've seen not many parts for them at all compared to the DE when it comes to turbo kits and the like.
but yeah..if you do a compression test and the motor is healthy - look around for some piece it together stuff - you'll get around 200rwhp for cheap as hell if you do it right.
wild_maxx
Car: 90 TT pearl yellow z32
ya **** that piece of **** kae. you dont want it at all. they cant even handle 1 psi of boost. get rid of it. might get about 2 bux for it.
BTW i run 15 psi daily on my kae.
WDRacing
LMAO...good post.
DOHC motors are simply better in design and theory. The motors have piston oil squirters and the head will flow better.
But for under 350whp, no swap is needed at all in my eyes.
DammitBobby
Car: S13 91 KA24DET
I might get flamed but if it was me I would stick a SR in it. The reason I would go that route is because you have a 16 year old motor that probably will not last long on boost. Limited choices for manifolds, downpipe and IC piping.
The car will be easier to sell with a SR motor rather then the 16 valve motor.
xplicit240
well a friend of mine just crashed his 94 240 but its auto .. my transmission should fit with that engine .. he has a de and it only has 100k miles on it .. i think im getting the whole car for under 500 .. so i can decide from there .. what would i need to do if i wanted to turbo the de to reach hp higher than 300 on it?
WDRacing
DammitBobby wrote:I might get flamed but if it was me I would stick a SR in it. The reason I would go that route is because you have a 16 year old motor that probably will not last long on boost. Limited choices for manifolds, downpipe and IC piping.
No might about it, you're simply queer
DammitBobby
Car: S13 91 KA24DET
You know you want me
xplicit240
lolz oh man .. here goes the flames~.. well if anyone has calipers they can sell me let me know prices.. and i am also lookinf for two front fenders ..
TECH question .. i hear squeeking sometimes when im riding .. can it be the brakes are rubbing on the discs? ahh i need help with this thing .. are 89 240's known for gauge problems? such as electrical ?? my e-brake light wont shut off
and if i get a diff front bumper .. will it look wierd on the bomex sideskirts and back bumper? if any suggestions can be made it will help .. to look at the car http://www.myspace.com/iamxpL click on the pix
Florida240sx
If you are going to turbo the SOHC then at least rebuild it and you'll be good to go.But being that dohc has onyl 100k on it just do the swap and have fun. Easy to get parts for both engines.But due to no oil squirters then keep the hp under 300ish for the sohc.Which is within your goal.
