RedHatchback »
https://forums.nicoclub.com/redhatchback-u17455.html
Sat Aug 07, 2004 12:36 pm
In order for you too get the EGR on to the header,you must first line up the header onto the head so that it just slightlyis slide'n of.You must then screw the EGR first before you even think about bolt'n it onto the cat or head.Once the EGR is screwed in,go ahead and fully press the header to the head.But don't bolt it on yet or else your gonna have loads of fun try'n to bolt it to the cat.Bolt it to the cat first and then go ahead and bolt it to the head work'n from the inner bolt to the outer in a criss cross pattern. After that,she's good to go.Oh there is one problem is that there might be a tiny exhaust leak,so go ahead and tighten the cat bolts preety good.
