Usually we get questions asking if cheaper gas is ok, since the car's manual, etc call for premium gas. the Engine is designed to run best on premium, and can be run on 87 when necessary.,mrayejay12 wrote:oh my bad, i have a 93' coupe. its a twin cam too unless that helps. yeah sometimes i get paranoid that my engine might fail due to the gas i use which is regular 87.
well i you read the gas on the back of the gas door. it says to use premium if you want better performance but 87 is fine.mrayejay12 wrote:Can i use plus or premium rather than 87 unleaded?
