Help on digital speedometer
mrayejay12
How do you fix a digital speedometer?
and how do you flush out the coolant and water?
im pretty air head when it comes to maintenance
onosqv
Car: '92 240sx Vert
You're also an airhead when it comes to searching :P.
digital speedo: search - in fact, you don't even have to search, it's on the "TECH PAGES" section of this forum under 240sx Tech Articles labeled "Repair digital speedometer with HUD" - if that doesn't work, search further.
flushing coolant/water: search... i.e. on google or here, type in "how to coolant flush" or even just "coolant flush" - I just did the search on google to check & first page should give you a good starting point. For specific bolts/locations if you can't find it on a 240, buy a Chilton's Manual or download the FSM from here - just one bolt @ bottom of radiator & coolant air purge bolt is on intake manifold. If you can't locate those by either looking physically or searching... maybe you shouldn't be doing a coolant flush w/o someone more experienced walking you through it in person.
mrayejay12
dude thanks a lot. i replaced my old plastic coolant tank for an aluminum one and i changed the radiator fluid yesterday. ima look into the digi speedometer section. thanks again buddy
