chmercer »
https://forums.nicoclub.com/chmercer-u5648.html
Sun Jan 02, 2005 1:10 pm
personally I would say the front is much more important to have in spec than the rear, in terms of lowering a car. In the rear all that is going to happen (generally speaking) is that your wheels will take on some more negative camber. in the front however, the wheels will also toe in, in addition to cambering in. in the rear, your tires will just wear more on the inside. leaving the front at such settings will cause your steering to be sluggish, and can also wear the inside edge of the tire much faster than camber wear. you should deffinitley get an alignment after lowering a car, but im sure you know this.
