help on buying a good cheap welder
sloweighty
Car: sileighty
i need help on buy a welder that i can used on my car and customer parts what i have been wanting to make. I also wanted to know if any of the welders that harbor freight has for sale are worth buying?http://www.harborfreight.com/c...etype=
CSUPUEBLOTIM
Car: 1992 240sx Sr20det Coupe Silvia Front
Try getting one with atleast a gas hook up. This way you will get decent welds and spend less time grinding little splatter everywhere.
duffman1278
Car: 89 240sx Hatch, the wildcats!
Cheap.......welder......in the same sentence??
I highly doubt you'll do this, and the price to quality ratio will more than likely convince you to go with a harbor freight welder but INVEST in a good welder, such as a Lincoln or a Millermatic. They have MIG/Flux Core welders for very affordable prices. I believe the Lincoln 140 iirc sells for about 500$.
Just note you won't be able to do thin aluminum pieces with a MIG.
sloweighty
Car: sileighty
i wasn't planning on welding aluminum but i know i do want a gas hook up dough. so the welders on harbor freight are not a winner then huh.....i also wasn't planning on using it everyday....just when it is needed.
Wc240
Car: 89 Nissan 240SX
97 Nissan 200SX
91 Nissan 240SX ka-t
06 Scion xB
2000 Nissan Frontier
if you buy a harbor freight tool, dont trust it with your life or to last more than two uses
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
I have a mig welder from harbor freight. If you can weld, there is no reason why not to use it.
IDRFT95S14
Car: 1995 Nissan 240sx SE
dude buy a good one for in the long run it will all worth it ,get a Miller for the win
mixeds14
Car: 240
\man i owen a harbor freight welder but its a flex core n the truth its not worth it if u r goin to weld on your car, as far as body panels n that sort of stuff, u will grind like hell n by the time u get a good weld on there you will warp the sheet metal. so i bough a lincoln mig(with gas) its a 110 but it gets the job done. i can weld anything up to 3/16 thick, i think you should just save up n get a lincoln or a miller, it be better on the long run...
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Northern tool and equipment has a very nice little gas Mig 130 for $270. Its their house brand, but considering it has a warranty from a very respectable company that has been in business for decades, its a solid choice. I would definitely recommend it.
http://www.northerntool.com/we...81941
I should add, my neighbor has this and it makes for some very pretty welds. Just don't be trying to weld anything thicker than 5/16ths steel. It will do aluminum pretty well too. He has had his for ~8yrs with zero problems. I actually used it yesterday.
sloweighty
Car: sileighty
r34 gtr wrote:Northern tool and equipment has a very nice little gas Mig 130 for $270. Its their house brand, but considering it has a warranty from a very respectable company that has been in business for decades, its a solid choice. I would definitely recommend it.
i guess i have found a winner.....thanks guys
