Tx-Sx-FS wrote:
** curiousity ** can i just loosen up the strut from body, then lift car with jack to relieve spring pressure and then take spring out and replace with this kit and lower car back down and tighten strut back down???????
Don't know for sure if the car can be raised high enough for you to take out the spring the way you explained. I guess one way is for you to try it.
What i used to do back in the day to replace the stock spring with aftermarket ones was....Remove the whole assembly (strut and spring as a whole) from the car. Get a tire (just a TIRE) place it against the wall on its side. Then place the strut assembly with the top against the tire, with your left or right foot standing on the spring. Then with your other foot place the sole of your shoe on the ground and bottom side of the sturt, so that the strut does not go shooting out. Then carefully loosen the top of the strut bolt.
The tire will absorb the load of the spring pressure. Just be careful that you don't lose the strut bolt.
But you have to make sure that your new springs is short enough for you to put on your stock struts. Or else your going to need a spring compressor anyways.
Good Luck...hope this helped.
