HELP: Oil Light
DriFt3r
Car: Racing and Drifting
I just recently replaced my oil and about 200 miles after I notice the oil light fading in and out. Like its going to come on but it doesnt. The light dims right before it gets to the brightest point. Also I just installed a Monster TACH, would that of had an effect on the oil light? I know the oil pressure is good because I have an oil pressure gauge and its reading 50 psi when I am driving. What could be wrong?
Get240DiZzY
Car: Rallying. My 240. Not at the same time though.
Check the dipstick to make sure you're not leaking/burning any oil.
DriFt3r
Checked that already and nothing is leaking and the oil is still full at the top although before I changed the oil I added a bottle of ATF to clean the internals and ran the car for 5 minutes then changed the oil, would that of have effected anything?
Mr1der
bear in mind it is called an idiot light
could just be a whacked out sensor
lok
Mr1der wrote:bear in mind it is called an idiot light
I like that, but check all of your fuses maybe something shorted when installed the tach. Kind of weird thought usually lights stop working when a fuse go's.
Did this happen after you installed the tach?
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
i definately with wonder on that one. go to the parts store, get a oil pressure switch, change it, stop worrying. if you oil pressure was really that low, you would know it. the main clues are when the motor seizes, makes grinding noise, catches fire, ect...
Megaseth
Car: 2002 Pathfinder SE
lol, actually, my engine has run on very little oil and its still doing good. the thing is, that damn light doesnt come on till the oil is LOW, and i mean LOW.
IvoryJ30t
yeah, if its bad youll hear it whining, or at least see metal in the oil.in one of my buddies beaters, just to see, he didnt change the oil for 30,000 miles!! damn chevy 3.1v6 was tough. finally died when the car was driven without coolant for about a month.
Get240DiZzY
IvoryJ30t wrote:he didnt change the oil for 30,000 miles!! damn chevy 3.1v6 was tough. finally died when the car was driven without coolant for about a month.
:eek:
IvoryJ30t
hahahaha, i can tell you the cool sounds that little pos made when it got hot. it was funny to see the temp gauge pegged past red for hours on end.
IvoryJ30t
he filled the coolant up about once a week prior, but then just stopped adding coolant altogether for a month. finally siezed.
