HELP: OIL LEAK
72nismo
Car: 510 / G35 / Murano
My wife drives a 2003 G35 Coupe. I started noticing oil spots in the driver so I jacked up the car and first thought it was the oil filter leaking so I re-tightened but no I notice oil is coming from behind were the oil filter is attached.Is that something that can be unscrewed after the oil filter is removed and replaced? Is that a common leak on G35? As you can c in the picture right behind the aluminum donut there is the leak.
Modified by 72nismo at 12:19 PM 2/13/2010
qship96
Car: 1996 Infiniti Q45
I believe that is the adapter for the oil cooler- it should just screw onto the block similar to the oil filter- it may have a gasket that needs replaced- look in factory service manual for more detailed info and pictures.
72nismo
I will do that. Thanks
Q451990
This sounds similar.
zerothread/351465
Modified by Q451990 at 8:01 PM 2/13/2010
72nismo
Fixed the leak.. All I had to do was replace the gasket behind the oil cooler and bam no more leak. Thanks for your help guys.
Q451990
That's great! It seems like this is becoming a common issue on the cars with the oil cooler setup.
Heath
