Help - occasional ABS light and humming black box
motorbobb
Car: 1994 q45t
I have a 94 Q45t. Over the last six months, on a few occasions the ABS light came, and stayed on. The light seemed to come on not as a result of braking (ie the pads feel strong) but when the car was started.
The odd thing is that when the car is turned off, a humming noise continues to come from the little black box next to what I think is the ABS unit (passenger side of the engine compartment near the firewall).
How have I got the humming to stop?? Good old fashioned american ingenuity -- a soft tap on the black box with the palm of the hand.
I am guessing that the black box is some sort of electrical relay for the ABS and that the relay is wearing out. However coming from someone who has resorted to fixing the problem by pounding on it, its obvious I need some expert advice.
Any idea about potential fixes and the costs? rgds kc
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Check the ABS relay.
Have you flushed the brake fluid yet? Old moist fluid causes ABS unit to fail, then big repair bill to owner.
driverdriver
Car: NICO's longtime resident Canuck!!!
If its the ABS relay/pump, it should be a failry straightforward DIY job after buying the part from a Nissan/Infiniti dealer(they're only availabe there).
artandscience
Car: 2012 Infiniti M37x, Brilliant Silver, Graphite
I had the same problem. There are two relays in that area that work with ABS. If one goes bad (as mine did), it will continue to humm and consume power even after the ignition is off.
I replaced both relays with new ones at the same time. I think it was about $35 per relay (not cheap) but that fixed the problem.
Q451990
I would check with Scottsdale on relay prices, but in all honesty I think they're pretty standard as far as automotive relays. You might try to buy one locally at AutoZone, etc...
Heath
