Isn't there a way to jumper (or maybe disconnect) the sensor plug? I remember seeing this on a honda board a year ago when I owned an integra. I would imagine that if that second O2 sensor was not sending any voltage, the ECU would:
A) interpret it as being lean exhaust condition or B) interpret it as being a faulty sensor
"Under normal conditions, the rear heated o2 sensor is not used for engine control operations." (1997 240XS FSM) Whatever normal conditions are??
Either way I think you'll still get the Check Engine light to come on.
Someone has to be more knowledgeable on this than me...
