HELP! Not getting any fuel!
Ramonesfreak2010
Car: 1993 240sx Hatch
Soo back in April, I got into an accident. My car was totaled. The plan was to buy another shell and swap everything over. Doesn't seem hard, right? I ended up buying another S13 for pretty cheap. It was running and everything. I took out the KA and started installing the SR from my wrecked car. Everything was going good until start up. I wasn't getting any fuel. I thought my fuel lines might have gotten mixed up, but they were correct. I checked the EGI Pump relay and fuel pump fuse. Both good. I even swapped them out my now parts car just to be sure. Still no fuel. Ok maybe somehow the fuel pump when bad sometime after I got the car. Installed the walbro from the parts car and still nothing. After some looking around I found a loose wire from the ecu connector. It was red/white #105 which is the Fuel Pressure control module. Ok maybe that was it. I repinned everything and hoped for the best. Still no fuel. I kept searching hoping I missed something. Found a plug right under the fusebox that wasn't connected. Connected it and tried starting up the car again. NOTHING. Could the ECU have gone bad?
I'm retarted when it comes to electrical work/diagnostics. Can someone lead me to the right direction? Its killing me! I tested the fuse with a multimeter and I got 12v. Don't know if that means anything??? lol
I read Heavy Throttle's FAQ's under "Fuel Pump won't come on" and it says "
Plugs by Battery may be wired incorrectly, they plug in but won't work without rewiring. Pump should run for 3 seconds then stop if flywheel not moving. " but the thing is, everything was working on my previous car perfectly. Something in the harness must have messed up in the process of swapping it over...
Thanks in advance.
S14toRPS13
So if you're getting 12v at the fuse, have you checked to see if you're getting 12v to the fuel pump itself? When's the last time you changed out the fuel filter. Are you getting fuel to the filter atleast?
Ramonesfreak2010
Nope. No fuel coming out the hardline. The fuel filter and pump are only about 2k miles. I'm about to go check the pump right now if I'm getting any voltage.
