During idle, for example, the vacuum signal is off. The ecu cuts the vacuum by sending signal to solenoid during idle. test for vacuum when you rev the engine. egr is on at specific times. vacuum supply is prob ok.
zer...a24de
one vacuum line goes to the area around the iacv. 11. all the hard lines run under the throttle. ii only see one getting vacuum there. the rest connect to rubber hoses and i guess go to the charcoil canister and aiv.
look up egr in tutorials in my signature.
Modified by vancouverbc at 3:05 PM 10/5/2009
Modified by vancouverbc at 3:18 PM 10/5/2009
Modified by vancouverbc at 3:23 PM 10/5/2009
