help, no transfer of power(91 sentra)
B13@15yrszold
Car: 1991 Nissan Senta xe
ii was taking it around the block and ii put it in first from neutral, and it wouldnt move, ii used 2nd gear to get it off to the side of the street, from there no gear would move the car.
[shifting the gears]the shifter moves but doesnt engage the gears. when moving the knob around in neutral, there is alot of nosie, when putting it into 3rd it is very rough, all other gears r just too smoth, liek nothign is touching. doesnt engage 3rd btw. The car also stalls when in neutral since this has happened.
ne suggestions?
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
What does the clutch feel like? Shifter fork damaged maybe. Only option you have before tearing the transmission off is to check the rear motor mount. If the mount is loose or damaged it will cause the transmission to do strange things.
B13@15yrszold
clutch is pretty smooth half way then it gets a lil harder to press, but the clutch seems pretty normal, this is the way it's been since ii got the car.
where is the rear motor mount located?
RED_DET
Vendor
2011 Infiniti G37x
Opposite end of the cross member from the front of the car.
