Oldnerdguy »
https://forums.nicoclub.com/oldnerdguy-u117851.html
Mon Oct 20, 2008 5:30 am
Lawless,Thanks for your help.Luckily I found some help with the electrical system and traced down the problem to a missing relay.In the engine room, there are 3 boxes on the passenger side. The biggest box is the main fuse box. The next one moving toward the battery is a relay box. It is long and skinny compared to the others, then there is a little one in front of those, closest to the battery. There was a brown 6-pin connector there with no relay. It needs a relay. It is the same relay as the Front Blower. The part number is 25230 7996A. The last 2 digits may not be a little different, like 63 or MA or etc. Basically it is the same as the relay needed for the Titan, so that should help the Dealer. It was $25.Plugged this in and worked fine. Used the trailer this weekend.Thanks again.
