HELP! No power when key is at acc, on and start!
Weezy
Car: 1992 240sx
Everything was running good until I turned off the car and decided to uninstall my greddy turbo timer so i can put in a newer version. I also took off my apexi afc. When I finished, I tried to start the car but it wouldn't start. Nothing happens when I turn to acc and on to start. I checked the wires that connected to the ignition with a volt meter and no power. If i leave the key in the ignition and leave the door open, the chime goes off. My dash lights up and i see the clock working. Fuel pump does even come on when i the key to on. I checked the fuses to see if any are bad but none are bad. I even switched out relays by the fuse box and the ones in the engine bay. I really need help here because I'm selling my car and i'm pretty sure no one would want to buy it if it doesn't work. thanks in advance.
777aaron
Car: race cars
Try checking your battery connection,maybe try to hook the stuff you took out back up if all else fails.Good luck.
