help!!! no power...
da mirakulist
Car: 87 RX-7 base model
Modified by da mirakulist at 2:18 AM 2/24/2010
240marcuSX
Car: E34 525i
E46 M3
i have no idea what your cars problem is, but ill help you in another way
da mirakulist wrote:bare with me....
i got mah car back from the shop from gettin mah rebuild head installed and mah fuel pump replaced. when i got it back i had no power at all, struggles goin up hill. Mah idle trips goin up and down from 700 to 1000 at the light. I tired complaining to the shop about gettin it fix but the mechanic refuses to work on it again, don't ask why long story... So i said f**k him then, I wasn't able to fix the problem. i realize he didn't put the timing correctly so i got that fix and i had to replace a vaacum hose do to a leak. it runs better but still no power and idle still tripping.
goin back when i fixed mah timing, when i put the timing correctly it wouldn't start until i f**ked with the injectors puttin it on and off.Could this problem be caused from mah fuel deliv.. or mah head being not installed correctly? Please help i'm not to fimiliar with cars that well........
any help will be highly thankful...
Modified by da mirakulist at 12:34 AM 10/25/2004
translation:
He says that he got his car back from a shop that rebuilt his head for him, and replaced his fuel pump. and now his car lacks power, and idles rough. the mechanic didnt adjust his timing correctly so he fixed it, and replaced some vaccuum hose that was leaking. but still no power, and still rough idle. something about putting injectors on and off in order to get his car to start after he adjusted his timing. He is curious to know if it is a fuel delivery problem that he is having, or if the mechanic didnt re-install his head correctly.
I hope that this helps.
/mah post
da mirakulist
yeah, haha sorry if i put it hard to understand
