HELP! NO OIL PRESSURE!
PervyDrifter
Car: 93 fastback
had a guy replace my headgasket and do my timing chain while he was in there on my 89. But when he starts it the oil light comes on. So he checked the oil filter after it ran for abit, nothing, no oil in it at all. So then he took the oil filter off,started and still no oil coming out. Changed out the oil pump and still nothing. I was pretty pissed off, was supposed to take it home today. So he brought down the oil pan and checked everywhere for clogs, nothing. Hes gonna work on it more on monday. Has anyone come/heard of this problem before? Any insight will be greatly appreciated.-and yes, theres oil in the engine.
driftneil
Car: A pile of cars.
PervyDrifter wrote:had a guy replace my headgasket and do my timing chain while he was in there on my 89. But when he starts it the oil light comes on. So he checked the oil filter after it ran for abit, nothing, no oil in it at all. So then he took the oil filter off,started and still no oil coming out. Changed out the oil pump and still nothing. I was pretty pissed off, was supposed to take it home today. So he brought down the oil pan and checked everywhere for clogs, nothing. Hes gonna work on it more on monday. Has anyone come/heard of this problem before? Any insight will be greatly appreciated.-and yes, theres oil in the engine.
Did you search?........He prob put the H.G. on upside down, And stopped the oil holes in the block.
edgartheace
Car: 1993 240sx, 1992 300zx RIP, 1993 300zx 2+2, 1993 Infinti J30t
It could be the oil pump drive gear since I assume you have the KA24E not the KA24DE.
PervyDrifter
Car: 93 fastback
-headgasket isnt upside down-oil pump drive gear is good
hes gonna take another look at the oil pick up to see if theres any cracks or anything. so ill know tonight if that was the case. im hoping to god it is. if not, any other suggestions?
Florida240sx
If he ran your engine for a few minutes and there was no oil pressure how is your head still good? No oil is getting through the filter? Or just the stupid light is on?
austins240
Car: 93 240SX HB, 89 Rolla GTS
i'm guessing the oil pump either needs to be primed or the oil pickup system needs fixing.
my friend had this same problem. turned out the bolts for the oil pickup to pump were loose. also needed a new gasket between the two. i'd check there, prime the pump and see if that works. sometimes it takes a long time to get pressure if you don't prime it but that's bad for the motor. make sure you have the top end lubed (valve cover off to oil all lobes) before starting or cranking for an extended period of time.
