goody90q45 »
https://forums.nicoclub.com/goody90q45-u31761.html
Sun Jan 15, 2006 8:21 am
[QUOTE=ceningolmo]I am not sure if these are related... but, boy, I sure hope you don't have similar problems to mine.
Thanks for the post. I've been following it since you originally posted it. If I do any of that type of installation I'll definately be driving to Best Buy in Alemeda to have Larry (chinanitrous) do the work.
I don't think my problem is as extensive as yours as I was simply removing a bulb. I've got the headlamp relay out and am now searching old posts for the P/N of the 90-93 unit. Once I verify that they are interchangeable I can drive to work and get the one off the abandoned Q.
The P/N from my '94 is 25230-68U00 found imprinted on its metal bracket between the two mounting bolts. If anyone has a moment, could they look at the P/N from their 90-93Q. The headlamp relay is right next to the under engine compartment fuse box, mounted on the fender, and can be easily read, no tools required (maybe a flashlight). Thanks
