Larz wrote:If you decide to go with a non-OEM (and who could blame you !) I'd go to The Retrofit Source. I would choose the Morimoto XB35 ballast kit. They used to sell a 'kit' with a wiring harness to bypass the OEM completely. If you call them, they can walk you through whatever you need. Some peeps are tempted to go with a 55w ballast, thinking it will make a brighter light. It doesn't. In fact, they burn out sooner and reduce the kelvin which makes your color lean toward yellow.
Yup, it sounds like that is the route I will have to take. I called the dealer and asked how much the ballasts are, and he told me one is $800. haaa haa. Yea ok !!
I actually placed an order for the Morimoto ballast already. I ordered these
http://www.theretrofitsource.com/compon ... iMv8fmrTb1
I will probably just order the other one and go from there. Of course I will consult with them first to see what they recommend. This no headlight thing is tough. My day is over at 6pm lol
