Straightsideways13 »
https://forums.nicoclub.com/straightsideways13-u155313.html
Fri Mar 05, 2010 8:54 am
so i think i figured it out... think would be the key word luckily i did get it fixed. i spent a good amount of time tracing the harness looking for any areas that were worn or corroded, witch by the way ended up being a lot easier than i had expected to get the interior out of the way. but what i had found is the loom is located in the wheel well on the driver side. my tiers rubbed a medium sided hole in the plastic guard, and it was raining when the problem started, i took out the guard to prevent more rubbing (im sure a lot of you know how annoying that can be) and moved that part of the loom up on the side of the frame under the fender where hopefully it will be safe. im pretty sure that the problem was that the wires were getting soaked and shorting the system, tho i could have just gotten lucky and "disconnected" the unwanted short while relocating the harness. thx guys for the ideas! and that diagram.
