HELP!! NO AUDIO, NAVI POWER!! 2003 G35 Sedan.
pyglee
Car: 2003 Infiniti G35 Sedan
2003 Infiniti G35 Sedan.I installed a navigation modulator to hook up my dvd player today. Everything tested out great all hooked up. When I was was putting everything back together, the radio, navigation, a/c & heater control and dash board light power went dead. I checked the fuse box and the fuse was ok. Please help!!!!
initiald711
Car: black s14,black eg9,black ef hatch
sounds like you messed up.if everything was fine before you touched.what and how did you install?
pyglee
I installed PAC AAI-NIS2 Aux Input for the audio and CARDEMAND NAVIGATION ADAPTERS for the RCA video feed. I purchased both products from eBay. They came with pre-made wiring harnesses. I followed the instructions that came with the products. Any idea what might have gone wrong?
initiald711
where are the connections?did you have to move the radio?
C-Kwik
I'd check all the connectors and wires to make sure they are making contact correctly and that no wire is damaged or pinched. I'd probaly disconnect the aftermarket items to see if everything is still working with it plugged in normally.
pyglee
Thank you for your replies.I found the problem.Strangely enough, the fuse for the power mirrors were blown out.I replaced it and everything worked fine.
C-Kwik
Glad it's fixed. Lets see some pics now!
