qat727 »
https://forums.nicoclub.com/qat727-u43939.html
Sat Jun 30, 2007 6:02 am
It's kind of messed up with the previous owner situation. I got it from a former friend that I no longer see or speak to, who bought the car mostly as-is and blew it up in 3 months time. He never would tell me who he got it from, so there is just a whole lot that I don't know about the car.
Someone did run a battery relocation "kit" to put the battery in the back. By "kit" I mean a completely ghetto rigged piece of crap that was incredibly unsafe. They beat a hole in the bottom of the spare tire hole with a screwdriver, did not install a grommet, ran a length of battery cable through the hole to the engine compartment and zip tied the cable to the frame rail so that it was hanging down in places. The fuse box they had installed on the battery cable was just an amplifier fuse block that had bolts installed instead of fuses, and it had been glued down with liquid nails to the old battery tray. In order to run the kit, the only thing they cut were the 3 leads that attach to the + battery terminal, which I happened to have an extra set of. So, I reinstalled the + terminal leads, and everything checked out on the battery circuit.
I'm not sure if you caught what I posted last night, but when I replaced the alternator, it now runs without the battery, so I'm getting at least some alternator output, likely full, but that will be checked ASAP. The current problem relating to the alternator is the battery light. I've checked all the wiring for it, except the lead from the inside fuse panel to the ignition switch, which I can not find.
If I just use the illumination wire, then the gauge would only be getting 12V+ when the lights were on, correct? Does the gauge need a constant 12V+ supply when the ignition is on?
Regarding all wires being connected, yes and no. I am sure all the wires are NOT connected. There has been an emissions delete performed on this car, so some of the wiring relating to said emissions equipment is left hanging. All other wires are properly installed, with the exception of an unknown set of wires going to the transmission that were cut and I have not found where they belong. I have driven the car up to highway speed, and I encountered no trouble with the speedometer or anything else to indicate something major on the transmission was disconnected, so I didn't bother with it.
