HELP!! no acceleration
Luke3x
Hey guys, need help with this one, beyond my scope.just had engine rebuilt. mechanic refuses to help with this issue.
anyway i just had my engine rebuilt after a blow. after all is said and done the engine runs again, revs fine and everything, mech says all boost leaks were fixed and has good compression and pressure. however, when under load or in gear and driving, the car will not accelerate even with pedal to the floor. it is inconsistent as well, sometimes will accelerate better than other. found best acceleration results when feathering the gas, barely pushing the pedal at all. on a side note, the engine does not cut off immediately after turning ignition off. runs a couple seconds then sputters out. any help at all with this problem would be greatly appreciated.
JGY customs is terrible.
Modified by Luke3x at 12:31 PM 11/13/2005
NISTECH
Start here
zerothread?id=143819
zerothread?id=139100
After your done reading the guide lines post the requested info so we can help you.
Welcome to nico
