HELP NISSAN TECHS DTC P0505 ON MY 2000 MAXIMA!!
VQboodah
Car: 2000 Maxima 5sp SE and 92 240SX
well about a week i got dtc p0505 iacv malfunction on my 2000 maxima. i tried to clean the iacv and still get the SES light back on. then i tried to perform the idle learning procedure on my car and still getting the SES light with the same code. i do not have access to the nissan consult tool, wish i did, that would have probably helped big. i searched for TSBs on alldata online and i did find that nissan had a TSB on it. I also search around boards and a bunch of people are saying they needed their ECM replaced??? any way to avoid changing the ECM and getting this problem fixed? i definitely dont wanna throw money into a new ECM. any pointers are greatly appreciated, THANKS!!
also for symptoms i am getting crappy idle that always bounces up and down. with the a/c on it also contributes to the problems
VQboodah
anybody?? yesterday i took out the throttle body and took apart the iacv and cleaned it with throttle cleaner but then when i put it back together, check engine light came back on for the same code. any help out there??
Ramius83
Car: 1995 240sx SE
Try replacing your Idle Air control valve and see where that takes you. The coil or something along those lines inside the IACV could have an open circuit, causing it to not function correctly.
We have seen where they start leaking coolant and thus, leak coolant into the connector. Then, the coolant acts as a conductor and creates a short and the ECU gets fried.
VQboodah
i think i might just have to do that. when i replace it, will that prevent that problem with the coolant issue? i'll update and repost on what's going on with the next step. hope i didnt fry my ecu
Modified by VQboodah at 11:19 PM 8/19/2007
jltibbs
Car: 2015 Nissan Versa SL
1994 Infiniti Q45
2000 Infiniti I30
ramius is right on target with that. get that thing replaced asap!
ymcm
Car: 2000 Nissan Maxima
I am having the same problem with my '00 Maxima engine code p0505. My husband has cleaned the IACV and he says it is not leaking. I believe that the IACV can be bad without leaking can't it? Leaking is what happens when you ignore it and then you fry the ECM, correct? Is there anything else that would cause the problems with the idle? When the IACV is disconnected the car idles fine.
Thank you, Yvette
jltibbs
1994 Infiniti Q45
2000 Infiniti I30
Welcome to NICO!
If the car has a rough idle with the IACV connected, but a smooth idle when disconnected, it's bad. I would look to getting it replaced to rule it out. Otherwise you may look into taking it to a dealership or shop that has a Nissan Consult scan tool.
jetroy240
Car: S13, AE86
Replacing the IACV is the first fix , then have the dealer erase the dtc, clear the self-learn & perform an idle air volume learn, that is if the wiring & connectors are ok, & re-check if the SES ligth will come back. If the same code comes back, chances are the old IAC motor may have knockout the ecm. Good luck.
Probably try to perform IAVL first & recheck, before replacing parts. You need a Consult 2 to do this.
Modified by jetroy240 at 10:44 PM 3/3/2009
Modified by jetroy240 at 9:36 AM 3/15/2009
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
You have to watch spraying cleaner in the IACV as there are electronicparts in there. You can check it with a multimeter to see if there isresistance and check the connector to see if it is getting volts.Chiltons will have the specs on it and I think the FSM will too.
ymcm
Thank you,
My Husband now has his project for the weekend. I'll let you know how it turns out.
Yvette
MNJAYHAWK
Car: 2000 Nissan Maxima GLE
I have recently had the same code being thrown by my 2000 Maxima. My car was having trouble idling and staying running (idling around 300rpm), so I checked it and the code P0505 was being thrown. Now since the rough idle problem my car displays the: ABS, TRAC OFF, SLIP lights. Could the idle air control valve make all of these lights come on? Or do I have 2 seperate problems?
Any help is appreciated! Thanks!
