Help!!! New Member! My key fob doesnt make the car honk anymore...?
All things Altima Coupe.
Nick Skilz
When I tried to lock the car using the keyfob, the horn does not sound. I thought the horn might have stopped working but it works when I press it. What should I do?
-Nick
Mr.Coupe
Car: 08 Altima Coupe 3.5 BOOSTED
There is a way to make your car silent when you activate the alarm so that the horn doesn't honk. Check your owners manual for intructions on it. It usually takes pushing a couple of buttons at the same time. This maybe happened when the remotre was in your pocket. Check the owners manual and you should get your answer to have it honking again when you activate the alarm. Hope it helps you dude.
Ricky C.
Nick Skilz
The manual had no instructions to disable/enable the horn when pressing the lock button on the keyfob. Pressing the lock and unlock at the same time seemed to reactivate the horn. Messing around with the buttons worked out. Thanks.
-Nick
srwong
Car: 2009 Altima Coupe 3.5 SE CVT
Nick Skilz wrote:The manual had no instructions to disable/enable the horn when pressing the lock button on the keyfob.
i thought the same thing when i had got my car and read my manual, but after finding out how to do this online, then later looking back in the manual... it DID have it in there... lol idk how i missed it
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
Welcome to the club!!!
http://forums.altimas.org/zeromain is the link you should bookmark!
All the info here is in its proper section (for the most part)... Please try and post in the correct area!
The search button works too, and we are always here to help you out! (again post in the right section if you can, if you arent sure, dont worry theres no beatings issued!)
ALSO, make useful thread titles that show what is inside the thread, i edited yours as an example
COME OUT TO THE BIG MEET NOV 8TH IN NJ!
michaelthepsycho
Car: 09 Maxima S
Press your lock and unlock button simultaneously until the lights flash. To reverse, simply repeat the process.
