Help! new here, fuel cutting out
Poker S14
Car: 1995 Nissan 240sx SE
ok, i have a few small holes in the top of my gas tank and was wondering if that might be the reason why the fuel is cutting out. no vaccum? i dunno, need help.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
My vote is fuel pump malfunction. The holes only end up venting the tank.
tyrodtom
Car: 90 240SX
If you're always running the tank with just a few gallons in it to keep the gas from splashing out of those holes, you might be causing your own fuel pump problem. The fuel pump ( it's in your fuel tank) depends on the fuel around it to keep it cool. If ypu're always running it low on fuel, that will shorten your fuel pumps life.
