Zion8561 »
https://forums.nicoclub.com/zion8561-u28751.html
Fri Aug 13, 2010 7:41 pm
Ok I think I have it figured out, but need a sanity check on this one just to make sure. We bled the clutch slave cyl and did get some air out, but the pedal still did not return all the way out. It would stop at the point the clutch engaged.
So I took a closer look at the clutch pedal "spring assist" and saw that it was busted. So in my theory, the only thing forcing the clutch pedal back out is the tension from the pressure plate. Once the clutch is engaged, the pressure plate is not forcing the slave/pedal to move any further out and it always feels like the clutch is engaging at the "last second". So that would explain why no matter how I adjusted the linkage, the pedal always stopped coming up at the same time the clutch engaged. The only thing that changed was the height of engagement...
I just need another mechanical mind to think this over and let me know if this is right. Please and thank you. I want to blast some mtn roads tomorrow...
