We adjusted Internal Wastegate for more boost. Went for another test drive car felt great boosted up to about 12 lbs which is way to high for my stock internals. Ran car again but this time car started sputtering around 8lbs. So we decided to re gap my plugs which for what ever reason were gapped at 40 dropped it to 28 went for another run but car kept stuttering so we re-gapped to a couple different gaps and no cigar.Even gapped back to 40 and it idles fine for 10 seconds and then it starts wanting to turn off.When I drive it once I start getting into boost the car starts stuttering like if I have a boost leak but we couldn't find one. Not sure if this is normal but when we disconnected the maf the car idles normal. Tried a different Maf and as soon as we connect it the car starts idleing bad and shuts off.
We checked compression and it was 190 all across, oil, gas, distributor cap, Changed spark plugs.
Any ideas what could be wrong?
SORRY FOR LONG POST.
SET-UP
95 KA stock internals, JWT ECU, 370cc Inj, ITB's, BOV, intercooler, Turbo, AFR Gauge, FPR.
