02pathy »
https://forums.nicoclub.com/02pathy-u44880.html
Mon Apr 13, 2009 7:07 am
for surface rust, honey goo is a really good product, there is also amsoil heavy duty metal protector which to me is like the factory rust proof when it dries(i use this to prevent it, honey goo to stop or slow down rust)
also when u guys are washing ur cars especially in the winter and springs months, don't forget the underneath, around the fender are very important, run ur hand along the inner fender carefully to remove loose dirtreplace dirt with rust protectant of ur choice once dried completely,
also for our truck, from what i have seen personally, is in the rear fender where the gas filler neck runs down, take off plastic covering in wheel well u might see 1-2lbs of dirt, again replace with lubricant after its all said and done
one other trick i have seen is to put grease(wheel bearing or other) in the fender on the lip
p.s. roger ur windshield is probably worse than it seems, i had to replace the windshield on my other car, i had no surface rust what so ever, but when they took out the windshield, there was rust at the top part of the windshield seating area, i had to grind it down, fill with liquid metal, and re-clear my roof all for about $400
one other thing is that its better to rust proof ur car in the spring, the guy at krown told me so, the humidity is really what starts to get the ball rolling especially if u don't wash the underneath of ur car
