srv2nv »
https://forums.nicoclub.com/srv2nv-u59620.html
Mon Oct 22, 2007 8:10 am
I'm installing 2 DVC Alpine Type R's in a single enclosure box (one box, open inside with 2 holes cut for the woofers) with a single interconnect and was just looking for feedback on how to wire the box.
I'm pretty sure I run a + speaker wire from the interconnect on the box to both Sub A and Sub B, then on each sub cross that over to the other + connector, then do the same for the negative, making sure all pairs of wires are the same length. Am I correct or should I be going about this another way?
If you need a diagram to see what I'm talking about I can draw one up, or if you have a diagram showing how I should do it that would be great, but I'm just looking for someone experienced opinion before I go ahead and wire it up.
