im keeping the stock coil and ballast resistor.
my transistor unit (ignition control module) went out and decided to repalce with a GM 4 pin hei. my ballast resistor is 3 pin insetad of 2 on a 240z. all the write ups refer to a msd or petronix coil and does away with the resistor ballast but no provision ive come across to keep the ballast on a 260z. heres the stock setup.
and heres where i am right now in the diagram.
