farfrom »
https://forums.nicoclub.com/farfrom-u231685.html
Thu Feb 20, 2014 3:03 pm
Hello.
I am new, and this is my first posting. I have combed through in search of some advice, but have come up empty.
Thus this post.
I am in the midst of draining/flushing the coolant fluid from my '96 Path.
I have the SERVICE MANUAL (SM) (Nov 1995) and am following all of the instruction to a tee, however I have run into a brick wall with the removal of the passenger side ENGINE BLOCK COOLANT DRAIN PLUG BOLT, namely, I cannot freely access it enough to get the torque needed to free her. I have even gone as far as to remove the STARTER, thinking that it's wiring harness was in the way, (to no avail). The problem seems to be that in the only positions in which the offset wrench fits flush on to the bolt, there remains zero clearance left to loosen, (on one side it abuts a pop-out in the oil pan, and the other lays on the alternator), and a ratchet will not fit. I figure that if I needed to remove the something relatively major as the ALT. (for it seems that with it out of the way access would be granted) that the SM would mention it. I guess I could leave it and just proceed with the flush, but ...
Any advice would be greatly appreciated?
Also, is there any way to bleed the air without making use of the AIR RELIEF BOLT/BLEEDER VALVE? Mine will not budge. The box end 10mm and the vice grips are only stripping the hex. I have ordered a new OEM, so I am open to all, any suggestions?
Thanks.
