Help! need Valvesprings for DE, roller rocker engine!
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
RallyNorway
Car: Nissan Almera N15 GTI Rallycar
Hi! A little time ago we fitted a set of JWT S3`s in our Almera GTI Rallycar, gained a lot of torque and power, but the valvetrain floats at 6800 rpm, we are desperately wanting a set of harder valvesprings, JWT is currently out of stock and will not have in about 2 months, anyone who knows if there is some other springs wich will fit and do the job?? Or maybe someone is having a nice set lying in a box in their garage?? Any suggestion is recieved with pleasure!!
PS! ROLLER ROCKER HEAD!!!!!!!
nametakennow
Car: '06 MINI Cooper S
Sadly, I think JWT is the only supplier around.
RallyNorway
Anyone tried with double springs?? Might be a standard valvespring from another engine/brand wich could be fitted together with the original one? Anyone tried this out??DESPERATE!!!
Chris859
Have you tried a set of normal sr20de/sr20det springs? The main changes in the roller rocker heads were the rocker arms, and cams.
RallyNorway
Anyone who knows if the springs from the "non-roller" would fit a "roller"??Would be nice to know before pulling the head off!!
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
