help! need turn signal bulb Id
xscorex
Car: 95 nissan hardbody,95 4x4 pathfinder , e46 323ci
ok went to autozone, Looked up in the book for replacement turn signal bulbs for the fron. They were listed as " multi" which means it could be a number of different bulbs. Great! it said to check my owners manual. which of course I dont have. I also threw the old bulbs away, as I was repairing the front end and was swapping them back & forth to try & test if they were both burned out. So now I have no way of figuring it out. I have a 95 regular cab 2wd hardbody. can anyone point me in the right direction to find out what # replacement bulb? thanks guys!
zack.
Car: 97 kc hb xe 2wd
xscorex
this is wrong. 1156 has a metal housing on the bottom, the bulbs that came out of my truck were small and were closed bulbs with 2 wires that would make contact when slid into bulbs socket / holder thing. crap. I guess Ill have to call nissan or take it to the dealer
rizzobc
Car: 1987 nissan hardbody
have you tried a 194 or a 194LL. I think that is the part # for the front corner lights, if that is what you are looking for.
xscorex
thanks Ill try that one. Its a tiny small light. it was the only one in the housing.
