guyaverage »
https://forums.nicoclub.com/guyaverage-u13673.html
Thu Sep 09, 2004 12:39 am
I had the same problem, what I ended up doing was on the one that has the nut plate missing, I used along sheet metal screw (about 1-1.5 inch length) that would screw into the structural foam underneath the bumper. Before screwing it in, I took a tube of silicone (any one of the blue, black, clear, etc. 'gasket-maker' type will work fine) and injected as much as I could into the hole, coat the screw with some silicone, then attach the license plate with the screw. Dont attempt to tighten the screw much, it will just eat at the foam inside. Do this in the evening and let it dry overnight, the silicone will act as an anchor for the screw and it will be plenty tight. I did this almost a year ago and mine is still tight as can be.
