bruinbear714 wrote:Ideally, you want it on the cold pipe RIGHT before the throttle body, so your engine will see the full boost the spring is set at.
If you have it on the hot pipe, you're engine will see a percentage of the boost, depending on the efficiency of the intercooler.
Very true. But if you are going to use an EBC I believe it is best to have it near the compressor outlet. Shorter lines, less prone to crack be cut or bent, and also the boost controller will let you reach the PSI you desire and once it gets there the WG will react more quickly... at least that's the reasoning I used when desgining my system.
