HELP! need to get these studs out!
HPR
Car: 1990 Nissan 240SX
I went for a 3 hour drive to a drift event yesterday, and on the way up 2 of my studs coming from the manifold to the turbo snapped in half! Today I pulled out the turbo and manifold and in the process of separating the manifold from the turbo for further inspection, 1 more stud snapped leaving me with only one intact.
Any trick to getting snapped studs out? They're pretty corroded and I prefer not to drill them out. Please help.
garagelu
Car: 1995 240sx w/ sr
Pb blaster does wonders if they are siezed in there. Also if you have enough stud, use a vice grip. But if its broken with nothing sticking out, you will have to drill it out. Not many choices.
GTS4-R
Car: my feet
and those are like super duper hardened since theyve been heated up and cooled 1.2 million times....Good luck!
Slipstream
Car: '94 Sonoma, '90 300zx n/a
Oxy-cetelene torch, bee's wax, vice grips, and a careful hand.
rustest86
Car: 93 240 coupe SR20DET Greddy T518Z, Tomei 256* poncams, sti injectors, and fmi
if theres anything sticking out have someone weld a nut to the broken studs, then spray wd-40 or your perferd penitrant. let it soak and spray it a few more times letting it soak. then work the stud out loosing and tightning untill its out. dont just try to unthread them because they might seize and break off more.
doridori23
Car: 1996 SR20deT 240sx (mine) , 1998 KA24de (wife's)
Soak them down a few times a day for a few days then use a 1/4" LEFT hand drill bit. Drill VERY slowly with a lot of pressure (dont put an angle on the bit or it will snap) and the bit will grab the stud and rip it right out of there. This technique works on everything including stainless and titanium.
PS WD-40 is horse urine compared to PB "Blaster"
karmakaze
Car: 98 240sx SE
doridori23 wrote:Soak them down a few times a day for a few days then use a 1/4" LEFT hand drill bit. Drill VERY slowly with a lot of pressure (dont put an angle on the bit or it will snap) and the bit will grab the stud and rip it right out of there. This technique works on everything including stainless and titanium.
(also known as "easyouts" if you go to a hardware store)
