pulsar gtr »
https://forums.nicoclub.com/pulsar-gtr-u1034.html
Wed Apr 06, 2005 1:03 am
Hi,
Here is how I usually do it and I haven't yet destoryed one.
Get a tourch, and heat up the crank sprocket, don't put direct heat on the crank, just go in a circular motion with the heat on the sprocket, then with two crow bars, stick them behind the sprocket and force it out, you need to put some force back and forth from one crow bar and then on the other.
It helps if you have some one to either hold the tourch and heat the sprocket while you do your work with the crow bars.Good luck,
PULSAR GTRRafi
