Help, need to change R&P Bushings...
Boricua
I need to change the two bushings that support the Rack & Pinion (Steering gear assembly) in my 240 1990.
i have already have the two bushings, i like to know if i can put this bushings w/out remove the entire R&P. the are an open bushings, (you can open...)
i wondering if i can put them only with remove the nuts in the brackets... :confused: or need more job to do...(can do "Do it your self" or need a mechanic), i now i have to align te whhels after that...
thanks
:help
NISTECH
yea you can do it get it up on jack stands crawl under car remove the 4 17mm bolts holding the rack in lift the brakets ..remove old bushings , install new bushings. install brakets and bolts tighten bolts.
Boricua
Thanks
that´s what i think.... :),i will do it tomorow
Thanks Again...
