elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Sat Nov 26, 2005 11:08 am
Did he pull the codes from the TCS control unit (in the trunk like stated earlier) or the TCM (throttle control module), which is located behind the dash...... it makes a difference...
Either way, code 13 for either module deals with the secondary throttle opening circuit... Which IMO most likely means the secondary throttle motor is bad....
Im going to have to do some more studying in the FSM which I am working on right now, but heres the basic outline. Unfortunately code 13 is one of the more complex codes, and according to the 1994 Q45 FSM that I have, the following DIAGNOSTIC PROCEDURES are all applicable to code 13 of the TCS control unit or TCM
10,11,12,13,14,15,16,17,18,18,20,21,22,23,25,27,29,31
Im going to read over those tonite and see if I can come up with something more conclusive.... Feel free to buzz me tonite at 765-621-8336 if you want me to help a little further.....
