Help! Need sizes on some bolts!
c-rad
Car: 1991 Nissan 240SX w/CA18DET
So the blasphemous machine shop that had my motor the first time managed to lose my bolts for the oil pump and rear main seal retainer. If anyone happens to know the sizes of these bolts, I will be forever grateful. It would save me from making 500 trips to the fastener store.
pulsar gtr
Car: NISSAN VEHICLES
the rear seal bracket is 10mm bolts I believe and the oil pump has 14mm bolts, but you should check with the fsm just to be on the safe side.
Good luck,
Rafi
c-rad
pulsar gtr wrote:the rear seal bracket is 10mm bolts I believe and the oil pump has 14mm bolts, but you should check with the fsm just to be on the safe side.
Good luck,
Rafi
I didnt see it listing the sizes of the bolts in the FSM... are they really in there?
jt15833
Car: 95' 240SX
if anyone knows thread pitch and length thatd help him out more
sideways danny
Car: s13, CA18DET
rear seal bolts are m6x1.0 (12mm long IIRC) Oil pump bolts are M8x1.25 in a couple of different lengths
c-rad
sideways danny wrote:rear seal bolts are m6x1.0 (12mm long IIRC) Oil pump bolts are M8x1.25 in a couple of different lengths
Yeah thanks. I managed to figure it out. Oil pump bolts are M7x1.0 just so you know.
