POS VETT »
https://forums.nicoclub.com/pos-vett-u23182.html
Mon Jan 17, 2005 2:39 pm
I have a KTS coilovers on my '95 S14 and I feel that the spring rate combo that came with the coilovers is a bit too stiff. Basically, the fronts have 448 lb/in and the rear have 336 lb/in. For discussion sake, let's say 450/350. The car skitters around rough corners and this doesn't do well in autox where the surface is rougher than near-perfect surface at the tracks.
Now, I'm looking for suggestions as what spring rates that will work better. I want to try moving the rear springs to the front and use 275 lb/in for the rear. Anyone used this combo (350/275) before ? How about putting half of the original rates, i.e. 225/175 ?
Inputs are highly appreciated.
