help. need info on differences between s13/s14 ka24de engines.
Vday Kid
i have a '92 240sx coupe shell i bought for a project. i am about to buy a ka24de for it. the motor and transmission are a '95. will there be any differences swapping the s14 1995 ka24de into my '92 coupe? if its gonna cause me too much of a headache i might have to wait and find an older ka24de. i think i read somewhere the 1991-95 ka24de is obd1. and the 1995-up is obd2. is that right?
Vday Kid
info on any differences is appreciated. any differences between sensors, transmissions, etc. also, will i be able to use a 92 ecu and wiring harness?
*quick edit.
Modified by Vday Kid at 11:50 AM 12/28/2007
DALAZ_68
Car: 90' 240sx CA18det
depending how early or late in the year the s14 engine is made in 95, determines wether it stayed obdI or II
if its OBD I then **** should plug right in...using ur s13 DOHC harness
Vday Kid
thanks. is there any way i can tell by looking at it, if its the older or newer one?
Vday Kid
bump.
no one knows of any visual differences between the obd2 ka24de and the obd1 ka24de?
