HELP!!! NEED FEEDBACK PLS
bomexs14
Car: Y33 Q45t
I'll start off with my knock sensor bank 1 went out so i decided to change out both knock sensor at the same time. now after i changed that i got a code for random misfire, again i decide to change out all the plugs and ignition coils all brand new OEM parts. I started up the car a few minutes later i got another for P0300 for random misfire. someone please explain this to me? how is this possible?
Thanks
Chris
Ozzie
Car: '90 Nissan 300ZX twin turbo - 2 seater
'99 Mitsubishi Legnum VR-4 Type-S twin turbo
'71 TA22 Toyota Celica (flat light)
'06 MK5 Golf tdi
and some motorbikes too
Try disconnecting your battery for 10-15 mins, so the ECU has a chance to reset, and check all your engine earth wires.
Make sure they are secure, and not broken or corroded.
If that doesn't work, a P0300 code is usually thrown when one of the following occurs:
Faulty oxygen sensor(s)
Faulty fuel injector(s)
Faulty spark plugs or wire
Faulty coil (pack)
Burned exhaust valve
Faulty catalytic converter(s)
Stuck/blocked EGR valve / passages
Faulty camshaft position sensor
Defective computer
I know you have changed the plugs, coils, etc...
Check/replace the leads and the O2 sensors, and make sure you don't have a vacuum leak first.
You didn't mention if the car is running rough, stumbling, or any other symptoms.
Is it doing anything like this, or just throwing the code?
bomexs14
Car: Y33 Q45t
Ok here's more updates, after I replaced the followings mentioned the car ran or I guess idled smooth, once it threw the code idle was stumbling and rough and it was also blowing white smoke out of the muffler, and I forgot to mention that I had to apply slight pressure on the gas pedal for the engine to start up.
