Hello all. This is an update After a month (maybe more) of stalling, I finally took my Q in to the Orlando dealership for the inspection. Nice people. The bill however, not so nice. They pulled up the history on the car and transferred my name onto the profile. Good news is - is that the engine was "fine". Runs extremely smooth which surprised the service consultant who said he could barely tell the car was on. No codes showed up but Im not sure if they did a thorough inspection of the engine like I asked...even tried to bribe him with some green but he said his techs knew what they were doing. A few of them own the older Qs he said. Anyhow after waiting (yes I waited) for 1.5 hours I finally got my car back with the following summary:
TECH NOTED BOTH TENSION RODS LEAKING.......490.00 (yes, I know)UPPER LINKS LOOSE..........................500.00 (did not know)AC COMPRESSOR LOCKED UP....drum roll.....1,286.00 (see below)LEFT REAR STRUT LEAKING....................292.00DRIVE BELTS DRY & CRACKED..................149.00RADIATOR LEAKING...........................666.50 (started the day b4)REAR MAIN SEAL LEAKING.....................707.00BRAKE FLUID DIRTY...........................69.95 (see below)TECH RECOMMENDS TUNE UP SERVICE............899.00
TOTAL...............................over 5 grand.
Ok. I know that most of the bill is based on labor. Got a really good quote @ Firestone for the a/c. approx 900 which is not too bad. The dealership also wants to convert the a/c from the R12 to the newer stuff. Kit and dryer is included in price shown above. Damned radiator! Luckily I check my fluids and noticed it was low. And the puddle of antifreeze under the car. Will be looking for an all aluminum radiator @ Napa. Oil leak is minimal but will replace the seal. Hey, I Just got new brakes at Firestone...dont they flush and bleed the line on all brake jobs or am I crazy. Will investigate that one.
The problem is that none of this will be to repair the engine. With over 190k miles on an engine there has got to be something to work on. Plus I also want to get rid of the hard 1st to 2nd gear shift in the transmission. Any advice on what I need to get started on?
