GseaQ wrote:That piece comes as a 2- piece unit from Nissan. Sometimes if somebody has trouble unscrewing the plastic screw they'll try to pry it out which breaks the anchor leaving part of it in the hole. It may not look like anything lines up correctly if that's the case. They do come in a couple of different sizes, but they're usually in stock so you could probably take one outside to your car to check the size.
You know, those fasteners are probably all over your car. Have a look at how your trunk liner and various trunk panels are attached. You may find the exact piece in there to borrow. First you unscrew the plastic phillips head all the way out of the anchor. Then just pull or pop out the anchor.
Glenn
Modified by GseaQ at 1:22 PM 2/3/2008
The F50 uses different plastic clips than the G-50, not sure about Y33. No Phillips (or other) center screws in the clips on F-50. Don't ask me how they come out (without breaking them), I haven't figured it out yet.
