HELP: Need a new RCA jack. Dealer wants $500 installed!
Pashdut
Car: 06' M35
So my RCA cable snapped inside the jack (red one). I cannot get it out as it's jammed in there deep. The only solution would be to replace it and the dealer says Labor=150 and Part=370. That is a whopping $520. He said he can give me a discount to $475 but that is still s*** crazy isn't it? Any suggestions? I couldn't find the part online so if anyone can locate it for sale, I would be really curious to see what it is selling for.
Thank you.
svard75
Car: 06 M35x
RCA jacks are typically open tru to the other side I'm not sure if this one is. Do you have a flashlight? Shine it in the white one. If it is just push it through. If it isn't then use a small flat head screwdriver (the really small ones you use to tighten your glasses screws). That should allow you to fish it out.
bejjutsu
Car: M35X ('06)
First off, that price is insane. $100 would be too much.
Check out this thread if you need to open the back up and get to the other side: post6407055.html?hilit=rca#p6407055
DeanM45
Car: 2006 Infiniti M45 Sport 1 or 2 mods
The panel just pulls off (held on with clips). Once pulled off you should be able to fix the jack and/or tap into the lines and run a set of RCA jacks up front (center console maybe?) for easier access.
Pashdut
Car: 06' M35
DeanM45 wrote:The panel just pulls off (held on with clips). Once pulled off you should be able to fix the jack and/or tap into the lines and run a set of RCA jacks up front (center console maybe?) for easier access.
Thanks! I had no idea it came off that easy. I took it apart, unscrewed the system and freed the crap in there. I will get a cable tomorrow to test it and post the result.
Pashdut
Car: 06' M35
Worked!
DeanM45
Good deal! Nothing is really hard on these cars aside from sending it down the road!
The Bodyguard
Car: 08 Infiniiti M35 black loaded custom VIPDOUT
08 Infiniiti G35 S sold 92k miles
08 Infiniiti M45 S sold 78k miles
07 Infiniiti M35 traded 53k miles
95 Infiniiti J30 sold 155k miles
Location: Cypress, TX (Houston) o.g. from southern cali (North Hollywood)!!
DeanM45 wrote:Good deal! Nothing is really hard on these cars aside from sending it down the road!
Nice job Dean!!! :dblthumb:
